We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
I can't give you a REAL answer but I can give you a theoretical answer based on the compressor map - where the compressor goes "off the map" into the "overspeed" region.
The compressor map I'm looking at is for a T04E 50 trim. This map was published by turbonetics so you might want to find a map that is guaranteed good for your PTE.
The idea is, pick a point on the upper right hand edge of the map, where you are maximizing boost and flow rate. The point I pick on this map is at Pressure ratio=3.2 and flow rate = 45 lbs per min. This info might be a little different for your PTE but I bet not much. The point I picked is kind of a guess, but hey, the max PR on the whole map is not much higher (3.4) and that is at about 40 lbs per minute, so you just need to guess where you will actually be running.
OK, going with PR of 3.2, the rest is easy:
3.2 x 13.7 = 43.8 psi absolute at the compressor outlet (~ 1psi drop in air filter/MAS)
43.8 - 14.7 = 29.14 psi gage pressure at compressor outlet
29.14 - 2 = 27.14 psi gage pressure in intake manifold (BOOST) (2psi drop in intercooler, piping, and throttle body)
So, about 27 psi boost puts you right on the edge of the overspeed region if you are flowing about 45 lbs per minute (450 crank hp). If you are flowing less air you could have more boost without going into overspeed, but of course airflow is what you want to make hp.
Anyway, this fits fine with the 25 to 30 advice you were getting from the other posters. Looks like anything over 27 is actually off the map and into "overspeed" which you can do up to a point. That's where things get a little iffy and if it were me I wouldn't push it past 30. If you want more boost get a turbo with higher PR capability, like a GT series garrett.
If you want a really good read on this subject look at www.turbobygarrett.com - look at "turbo tech" "turbo 103".
Gary
Gary
1000's are defently the route to go.
