Maunal tranny problem!!!!!
erictheduk
Jun 11, 2012
Fargo, North Dakota
I have a 91 Talon TSI and was driving down the street today and got stuck in 3rd gear. I can shift into other gears way too easy but tranny stays in 3rd gear... checked linkages they were fine.... Did I smoke my tranny? Car has 89,000 miles on it... :(: PLEASE HELP maybe froze up clutch??? stuck in gear.
The only possibilities I can think of are linkage or a broken shift fork or broken rail end. Linkage is easy to check. Check the levers at the transmisssion. If it's in neutral but acts like its in gear then you broke something inside.
Exactly... sounds like it might be a shifting fork. Keep us updated.
Also could be shift fork roll pins. Kinda nostalgic now 14 years later when weak shift fork roll pins aren't a big discussion anymore. We here actually found that heavy clutches combined with driver inexperience was breaking forks and pins. Couldn't tell you the last time we've ran steel forks.
I had a similar issue before, I thought my tranny was done, but when i took it off I found it was in fact the clutch. It was an exeddy clutch and one of the springs had broken out of the clutch itself. Tranny was fine. Id take it off, as you have to really, and just check the clutch out then check the fork
If the shift levers are in neutral and it still acts like its in gear it cant be a clutch. A broken clutch would simply not disengage so no matter what the input shaft would spin just like it does when you're just sitting there in neutral. A broken clutch might keep you from coming out of gear but with car off it shouldn't do this.
That would be awesome.... I will obviously pay you for your time.... I know it must be a problem in the tranny I have all tools necessary to fix. :)
yeah I hope it is just a shift fork.... I think it is too THANKS :)
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
