Massive Clutch Slippage
the1cancer
63
Aug 18, 2004
Riverside, California
I have a brand new rebuilt bottom end, new XACT flywheel, new RPS clutch and pressure plate, new master and slave cylinder, new pivot, forks and TOB. I installed everything listed above about 1500 miles ago and there was this odd ticking noise coming from the bell housing, I didn't have the time to take the tranny out again since I started my job and after a few hundred miles the ticking stopped. recently I noticed that my clutch was slipping and it gradually started to get worse to the point where I had to floor it just to get going from a stop. I finally tore out my tranny again to find that the clutch was fine but my fork had a big groove notched into it from the pressure plate (hence the ticking at the beginning).
Does anyone have any idea why with everything brand new why the fork would be hitting the pressure plate?? also the handle of the fork is forced as close as it can to the slave. what would cause that?? and what is causing my clutch to slip so much, this is getting rediculus to drive.
Thanks for the help
yeah, I have looked at that site and read it many times and I didn't really find my answer there, thats why I am asking you guys.
I dont really see how a micro-inch or two can cause the forks to have a 1/4 inch groove etched into it by the flywheel. and I cant machine the flywheel too much cause its already really thin from the factory.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
