Clutch slippage! Noooo
Bubbas Garage
30
Mar 25, 2012
Watertown, South Dakota
Well, just got done doing a trans swap ( auto to manual) Supposedly the manual is a shep stage 3 with short shifter ( no way knowing unless i take it apart) and act 2600 cltuch.. Anyway, just got it running better so i went and drove it for the first time. romped on it a couple times... then i seen a buddy in a duramax so i went and got next to him and showed him ### it had.... untill my clutch slipped like a mother***** and looked back and seen a nice cloud of white :/. So were gonna look at it tonight and make sure its all adjusted right tonight. But, if not... What size clutch you guys think i should go with? Plans for the car are just weekend street car, take it to the dragstrip every once in a while. Id estimate the car to have 400-450 hp. But, would like a clutch thats good to 500 since i may up the boost in the futer. heres my mods
Engine: 2.0
Ross Pistons
Eagle Rods
SBR Stage 5 ported and polished head
FP 2 cams
Magnus Sheetmetal Intake Manifold w/ bungs for direct port N2O
Trans:
Shep Stage 3
Short shifter
act 2600
Mods:
VRSF FMIC short route piping
FORGE recirculated BOV
Dejon Tool Intake
Evo 8 MAF
DSMlink V2.5
LC1 Wideband
Buschur Racing 3in turbo back exahust
2.5in O2 housing with external dump
Turbonetics t3 exhaust manifold
hy35- 25psi
-4 an feed
-12 an 2g cut return
Dual Piston Front Calipers
Manual Rack and Pinion Steering
Battery relocated to the hatch
Fuel System:
PTE 1000cc injectors
Aeromotive FPR
Walbro 255 fuel pump
act 2900 whatever works for you 6 puck clutch. Theres tons pos/threads about people asking what clutch for 400-500hp.
Thanks for the reply, at this point im mainly wondering if you think it could just be improperly adjusted or is it just not a big enough clutch?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
