MAS removale?
Are you referring to an SD setup or just taking your MAF out, if it is the latter, you will need a miracle to run without your MAF properly.
You would need to convert to Speed Density, so the cheapest way would be to get an Evo 8 ECU and jumper harness to connect it to your car, a GM Map, GM IAT, EcuFlash and EvoScan and a OBDII to USB cable.
So price wise you are looking at probably 500.00 or so, maybe a bit more.
