MAS Question
wcpierson
296
Sep 16, 2005
Cedar Knolls, New Jersey
ok i know im probably gonna get bashed for this but i work in a hospital and dont have lots of time to do research on the site.... what are the benefits of putting a 2g Mass Air Flow Sensor on a 1g? is there any articles someone could post for me or explain to me real quickly and are there any articles with pics for an install and such? any info besides being bashed will help...thanks :thumb:
a 2g maf will support more HP!! 1g MAF's suck...I'd say Go and get a GM maf and run a blowthrough setup!! You'll gain more HP outta that then a 2g maf setup! :thumb:
what do u mean by blow through setup? and i read that thread earlier but its still not clear to me. Does the 2g Mass Air Flow Sensor allow more aiflow? and does it just swap on? does the 2g plug straight into where the 1g used to?....please someone help me with this cuz if its a good mod to do to my car as a newbie id sure like to do it
As for your first question...No a 2g MAF will now flow as much as GM MAF!! As for installation of a 2g MAF...Basically, Buy or Build an intake pipe for the 2g MAF and filter!! Then splice a few wires! A blow-through setup uses a GM MAF which has virtually NO restrications!! With a Blow-through setup u install the GM MAF on the UICP!! U then need a GM MAF Translator!! You will now be able to correctly VENT your BOV and have Fuel-control!! As for an intake on a Blow-through setup...Either make one, or through a Filter on the turbo..that simple!! You'll gain HP out of a Blow-through setup!! TONS of people run them...Search the forums for Blow-through Setup!!! Hope this is the information you were looking for!!! :thumb: Good Luck Bro!!!!!! :rocks:
