MAP sensor Resistor mod
Xtreme Legion
94
Apr 18, 2011
Springfield, Massachusetts
I was told, and maybe I heard wrong, that you can hook.a, specific resistor into your MAP sensor that helps gain power. I guess it signals for more fuel causing you to run a little richer.
Can someone clarify this for me. if it does work.would love to do it.
Sent from my HTC Glacier using Tapatalk
Its a resistor that goes to the IAT sensor. It basically tells your computer that the air coming in is cooler than it actually is and the ECU dumps more fuel in the motor causing you to run richer and actually lose power. Along with getting worse gas milage.
