map sensor question
Scott_S
182
4
Feb 17, 2006
Austin, Minnesota
When swapping to a 1g intake mani I know you need to plug your map sensor into a vacuum line behing the tb but how do you keep that line on the map sensor?
I know where to plug it in so to speak, what I was wondering is how do I keep the vac line on the map sensor itslef?
what I was thinking about doing is making an plate type thing to match the falnge on the map sensor with a hole in the center for the vac line with some sort or clamp type thing to hold the line in place when the bolts are clamped down. Kind of hard to explain. But thanks I might do that instead, sounds a bit easier.
I think someone make a pate that attaches the line to the map sensor. Also if you have dsmlink you don't need it cause it's only purpose is for the egr.
