Ramsey91
- 65
- 9
- Oct 15, 2022
Basalt,
Colorado
Alright so I’m having major over boost issues and I’m kind of stumped right now. I’ve tried two 38mm wastegates and a 44mm thinking maybe 38mm was too small, but same issue. I thought wastegate may be stuck but considering I’ve gone through three new ones it’s doubtful. Gonna bench test them though to see what they are opening at.
I’m running a gtx3071 on SD and bypassed ebc by going straight from the compressor housing to the bottom port and top port vented. Also checked for leaks but I haven’t found any. I’m gonna boost leak test it again and spray everything with soapy water to see if there’s any small leaks.
What else should I be looking for? I know positioning and flow is important as well so maybe this is the issue? I can post pics/video of setup if needed.
I’m having the car remote tuned by Ricky at rixracing and he’s been helping me but I feel bad constantly asking him questions considering how busy he is. I’ve also been doing research but wanted to ask to get some more input.
I should also mention I’m just trying to see base pressure so I can start tuning. I’ve used a 9psi spring combo, 14psi combo on 38mm and 11psi spring combo on the 44mm. I saw almost double base on first attempt and let off immediately. The other attempts have been acting the same but I've been letting off as soon as it goes over. Boost starts building at 4krpms and starts to really let go closer to 5k.
