Main Girgdle Question
LiquidX
DSM Wiseman
8,280
132
Sep 19, 2008
Anywhere, Pennsylvania
I plan on picking up a 6 bolt block with crank and both are used. I'm going to be doing a full rebuild. I also have a 7 bolt at home that had rod knock. From what I have been readinging is that the 6 bolt doesn't have a girdle for the mains. Will the 7 bolt girdle bolt up fine or are the holes not aligned? If not, then I suppose I'll be going with Kiggley :thumb:. Also, will the 7 bolt oil pan match up to the 6 bolt as well?
