Main Bearing Bolt
rennat
Nov 12, 2006
Tracy, California
First off, yes i've searched, but I just want to make sure what i found is correct.
The main bolts should be torqued down to 18 ft/lbs and then an additional 90-100 degress... correct?
Have any of you torqued them down to say 25? 40? 60+?
It's not that i don't have faith in my manual; It's just that it torque my axle nuts on my bike tighter than that... so im just making sure.
Could i torque them down to say 30-50 ft/lbs and still be fine?
Thanks,
Tanner
I would follow the manual if I was you; I did when rebuilding my motor. Torque is generally more about sequencing than ft/lbs.
On the main caps, I did 18 ft/lbs and 90 degrees.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
