Maft or 2g mas
dsmsucks
660
4
May 14, 2005
Rochester, New York
I would like to know what you guys thinks would be best for my current setup. I dont plan on going bigger than a 14b and 550cc injectors. I would also like to know the tunning difference between the maft and 2g mas.
Thanks
2g MAS is plenty for a 14b turbo. You don't need a MAFT unless you want something bigger. They also give you the ability to tune air/fuel a little as well
2g MAF is definatly enough, but there are added benefits to the GM MAF+translator. Such as what was already mentioned. It also will work in a "blow-thru" configuration alowing you to vent you BOV if you wish to do so. AND, there are no freakin honeycombs, so when you do decide to make more power, you're already covered. The 2g MAF will take you far, so it is really up to you. Good Luck! :thumb:
