maf or ecu problem?
donut
Mar 10, 2009
norwood, Missouri
I have a 92 talon tsi fwd and when i drive it for about 15 miles, and when i stop it idles really shitty if it idles at all then it misses until about 3k rpm then it drives fine under boost. i got the codes for air temp sensor, barometric sensor, tps sensor. The air temp sensor tested good the tps also tested good. but when i tested the codes today i got the code for the ecu so i reset the ecu and the code went away but i still got air temp, barometric, tps.
What could be wrong? thanks
It has no boost leaks and the bov is recirculated
