Machining 1g Forged Pistons?
tom04841
611
6
Jul 21, 2004
Rockland, Maine
I got a line on some cheap 6 bolt 2.4L wiseco pistons. Only thing is I have a NT Spyder w/ 2.4l 7 bolt. I want to do a mild build. I want to keep the stock rods if possible. So i guess here is my question.
Can I have the pin bore on the 1g wiseco's machined 1mm to fit the 22mm pin? If so, is there anything else i need to do to the rod since the pins are full float?
If not, Roughly how much would it cost to have the big end of 1g big rods machined to fit the 7bolt crank? And if machined, which bearings do i use now.....I would assume 7 bolt right?
