maby a stupid question
tcavenger99
109
May 24, 2008
mount pearl,
with a wide ban and lb injectors what should the wide ban read if running properly . is it the higher the number the richer or is it the lower the richer . my wide ban reads 14.28 at idle then shoots to 16 at boost (11 psi) . on another note the big black box on the lower part of the back of the intake what is its purpose ?
To ensure that your wideband is functioning correctly you must have no exhaust leaks before the sensor.
Higher is leaner, lower is richer. It is a Air:Fuel ratio. A reading of 14 would be 14 parts air to 1 part fuel.
At idle you would ideally want your wideband to read stoichiometric levels, about 14.7.
At boost on pump gas most people shoot for around ~11. 16 is way too lean.
so what woudl the safest rainge to fhoot for . right now i have the larger of the three disks in the sfmu .
at 16 to 1 a/f you ar getting to a piston melting point you want really close to 11:1 to 11.5:1 with no knock just to be safe you are gonna need a biit more fuel before you do anything else
OP has no MAF/MAS.
SFMU is a regulator with an adjustable base pressure and rate of gain.
On the bottom side of the intake manifold? A vacuum reservoir for the cruise control.
