WES_393
DSM Wiseman
- 3,814
- 100
- Jun 6, 2011
Colo Spgs,
Colorado
I just got my TSi up and running and I'm in the midst of working out some bugs. One of which is the cooling system. The water pump has 1K miles, engine and head were hot tanked and scrubbed in both the coolant and oil passages, radiator cap is brand new, and I just replaced the thermostat today. Yet after a quick cruise around the block, the fans are on, the upper rad hose is blaring hot, even the thermostat housing is too hot to touch, yet the lower hose is quite cold. Not ice cold, but nowhere even close to the top hose or T-Stat housing.
My initial thought was junk thermostat. I pulled it out and tested the new one in a pot of hot water. It opens up at around 190* which is a little late, but it still fully opens so I installed it. No change. Next thought was a clogged radiator, but when I had it out of the car it was flushed both ways with a garden hose for a good 20 min at a time. Coolant is about 70/30 if water/coolant and the gauge never reads above half way. Link even tells me it's around 200* at idle. No leaks or bubbles and the system is completely burped. I never even got above 3500rpm since I'm still breaking in the new clutch.
Am I just crazy or does it sound like something in the cooling system isn't working correctly?
only thing i can think of is that heat rises and maybe the air flow from the car is cooling the lower hose down and everything else is just hot from the engine bay temps. i dont think its something to look away from but it could just be how your car runs not completely sure tho.
