95 gxs lower radiator hose
ranger87
53
Jan 23, 2008
newberg, Oregon
Ok heres the dillema, if this is the wrong section my bad. Here goes, I was installing new radiator hoses on my buddies 95 gsx and cannot find the correct lower hose for his car. I have went through 2 different parts houses with no luck, all of them are to short by like 2 or 3 inches. The car is totally stock other than the stuff we have put on it. I any one can give me a part number for napa or schucks that would be awsome, ### his hose is way bad and the local dealer is about a 5-7 days out. The goodyear number and the dayco number are not right in their books and computer. If you need more info let me know. Thankz
Your not going to find it at any autoparts stores. Only dealership or internet.
I was having trouble getting an upper one for my 95 awd also. Either it was too short, not the right bends or simply too long with the wrong angle on the bends even if it was cut to size. I had tried autozone and napa. I would suggest taking the old one with you to the auto parts and start comparing if you haven't done that or simply place an order for one online.
I learned this lesson the hard way, old one was split and had to get something working cars a dd. We ended up splicing some of the lower rad hose that was still good, and buying a flexible hose from advanced and attaching them together. Knock on wood everythings held up for 3-4 months now.
The part number for goodyear lower radiator hose is #62191. You should be able to find it a Autozone.
