Low Idle. Dies easily
fritzer523
Jun 27, 2009
Mukwonao, Wisconsin
I recently picked up a 95 eclipse. It is a 2g turbo.
When idling it stays really low(below 1000), and will kill after coming down from high rpms. I asked several people and got some theories. I'm hoping to be able to fix it on my own before having to take it in.
Im going to go with your timing is off. Check from cheap to most expensive. Bov, boost leak, plugs, timing.
Check throttle body, any leaks, timing, etc and if everything shows good, could be your tune. Might not be getting enough fuel or something similar. Nothing that can't be fixed.
Try disconnecting the + battery terminal, let sit for 30 sec and then reconnect, start the car with no radio, headlights etc, and let idle for 10 minutes.
