low fuel light located?
birdii
135
Sep 7, 2005
ON, ON, Canada
i just bought this car and just wondering if theres a light that comes on when your low on fuel? i almost went empty and still didnt see any lights... if there is one where is it located? when my car starts up on the left side on the dash everything lights up like check oil light, parking brake... etc.... but on the right side nothing lights up... is there supposed to be something there to?
thanks
There is a low fuel indicator. It is orange and has a gas pump on it. It comes on when you get down to three gallons of fuel remaining in the tank. It should light with the test sequence at start-up, so if it does not, you might pull the gauge cluster and see about replacing the bulb.
Taking the cluster out is not difficult. If memory serves me right, you only need a phillips screwdriver (a shortie to get to the two screws at the top of the bezel) and maybe a slotted to help pop trim out of place.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
