fourgsixthree33
- 1,244
- 46
- Oct 25, 2010
Athens,
Pennsylvania
I recenty had a bad injector on cylinder one. Thus running on only 3 cylinders. A couple of great guys from here came and helped me out. Found the bad injector, and retimed the engine (took of timing belt, reinstalled). When we tried to ground the timing with that plug thing on the firewall, cylinder 1 would drop immediatly. Unground it, cylinder 1 back. What would cause this to happen?
Next, my Talon has the stock 390cc injectors from the automatics. We now have a 450cc injector on cylinder 1. Timing is now set perfect as it was off. But now there is no power what so ever. Although the engine runs smoother than it ever has before. No sputtering, just not power. Any ideas as to what would cause these couple of problems?
