loss of power when shifting and braking
ctomes26
Sep 26, 2009
Terre haute, Indiana
I have a 94 tsi when I shift from 1st to 2nd and 2nd to 3rd and whne braking I will lose power and almost die sometimes do but usually after a second or tow it kicks in and will go. has new fuel pump,16g turbo,and short shift.any thoughts
I'm with them, I'd make sure the BOV is recirculated and then do a boost leak test, make sure all of the couplers are tight, check vacuum lines, etc.
tried everything still does it I thought it could be in the fuel system not getting enough pressure pulled the fuel pump. I pulled it again and the filter was already pretty covered in sediment so i cleaned it and am going to replace the inline filter to. any other suggestions
