AWD97DSM
- 0
- Sep 28, 2006
Kalamazoo,
Michigan
I have gone through 3 turbos in the last month with oil changes inbetween each one. Oil pressure is ok wating on an oil test. I am wondering if moving the oil feed line supply down around the oil filter will help. Does the stock location supply enough oil pressure for a ported big 16g? I am running 20 lbs of boost with supporting mods. What else besides oil issues would cause a turbo to fail? I do have a turbo time from blitz. Any other advise on keeping a turbo in good working condition would be very helpful
...the engine has only 6,000 miles on it and i am running about 20 psi with the evo big 16g. what is the best way to keep a turbo from overheating at 20 psi??? there has to be a way... i am going to switch the a holset this winter...and i plan on moving the oil feed line...i also know that they dont overheat and are not liquid cooled...how is that so?? thanx for all the help so far
