need help losing my mind
Gsxxx
40
May 31, 2014
Dry creek, West Virginia
ok so here is my story i bought a 99 gsx automatic off of a dude about a year ago. he said it was overheating so i put a new cylinder head, head gasket, water pump, thermostat, valve cover gasket, intake manifold gasket, water outlet gasket, on the car and it is still overheating. so now i am gonna buy new radiator, radiator hoses and radiator cap. All my fans work i filled my resivor up yesterday and now it is empty but its not leaking i dont understand. i have had the car for a year and have barley drove it. and another thing my alarm sysrem keeps going off for no reason i have to take the fuze out to keep from hearing the horn. it does it randomly. so any advice would help.
Rent a cooling system pressure tester at Autozone or Advance Auto. If you're losing coolant, it's either leaking, burning, or boiling over and getting dumped out. The pressure tester will help you find out if there is a hairline crack somewhere causing an issue. I've had a problem on a past car where there was a hairline crack in the thermostat housing causing the coolant to boil over and dump out of the overflow tank when fully warmed up.
as far as the alarm check your hood switch you might have to adjust it or the hood to press it down further . one thing about the overheating did you install the thermostat with the jiggle pin at 12 o clock .
take the thermostat back out and install it properly otherwise you will never get all the air out of your cooling system.
yea we did bleed the cooling system but imma try to reinstall the thermostat
peak 50 50 its weird im losing coolant but its not leaking at least not where i can see it. im thinking about flushing my block out maybe i have some blockage in there.
Sounds like it could possibly be boiling over and just going out the overflow. You'd never see it while you're driving. I personally run ~ 70/30 water to coolant mix and have no overheating problems here in Texas.
Things I'd verify is thermostat installed right, no air in the system, and the radiator cap. The cap is a cheap investment that keeps the system pressurized and operating correctly.
Agreed with all of this - start here. Air in the system can be a bi*** to track down presenting as a few other issues when in reality you just need a good flush.
