Look at this pic
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
when i had my exhaust done i also had them put in a 1g tb but it reved high so i took it out and put my stock 2g tb back and ever since its been acting crazy, either reving high 1800 or stalling now if u look at the pic aren't their suppose to be lines connected where i have the black tie raps the place put those in but they werent always their maybe thats why i am stalling,, reving high and i did leak tester air is coming from their and tb gasket i dont know why i do have 1g tb gaksets on the 2g tb and egr blocked off, can someone take pic of their 2g tb and tell me where the 2 lines go? :dsm:
thanks :thumb:
do you still have your stock Emmissions crap in? look at this and see if you can follow it...
Taboo racing diagram
that shows how to remove it, which it looks like was started at least. you should just buy some small rubber vacume plugs to cap off those ports.
The reson your idle is off is you have a big vac leak due to those ports being open like that.
Hope this helps and good luck.
Mike :laser:
the only thing i took out is the egr and i have the ports plugged but what i am saying is stock it wasnt like that the palce did that shoudnt their be lines from the ports pic from a 2g would help
