Look at this pic and pls tell me -
90CherryTSI
Banned Member
420
5
Jan 24, 2004
Austin, Texas
the headgasket on top is the 4G63 2.0 HG from felpro, the black HG is the EXACT same shape, same holes and everything lines up the exact same but it was purchased in a head gasket set with the metal gasket/thing below it )not sure what this is, the exh manifold bracket/gasket for a 1.8 420A?) and a valve cover gasket with one hump for the 1.8 SOHC. Are the HG's the same for the 4G63 and the 420A? If so what is that metal thingey? Thanks!
lower right hand corner of the headgaskets are different, metal thingy looks alot like an exhaust manifold gasket for an nt.
Sike, edit, I think the plastic bag is just covering up the lower right hand corner a little....you can kinda see it blurred how they overlap, I'll post another pic. The gasket set says 4G63 on it, I bought it on Ebay from someone and Ebay determined he sent me the wrong product. The valvecover gasket and that metal thing set me off to it being wrong as I swear the HG's lined up perfectly....I was going to resell it but want to make sure I list it as the correct product.
there are a few more discrepancies, if you lay the blue and gray one over the black and red one you should see a few more missing holes. the black one looks closer to what i remember for my headgasket though, but the manifold gasket is definately way off from anything 4g63.
The bottom one looks to me like it could be an exhaust manifold gasket for a nissan sr20 mottor, the bolt patterns looks too me like the same as the nissan. It could also be for a honda i think they could quite possibly have the same bolt pattern but not entirely sure.
