Logging with MMcd
SiNiST3R
347
May 10, 2004
NorCal, California
Okay I know am betting a dead horse with this here is what i have;
I own a Palm V with OS 4.1
I have the Sync cable for it
I also own a Digimoto for my laptop Comes with a translater card (ISO) and the OBDII cable and a cable to connect to your laptop.
what i did is use the ODBII cable and pluged it into my Sync cable fo rmy Palm, And thats a No Go. Is there some kind of translater card i need for the Palm? if so where cna i get this at. I have the software and everything else running just not cutting it. I own a 2gen.
Thanks Guys, SiNiST3R
buy a 9 pin null modem adapter to go between your diagnostic/laptop cable and the Palm hotsync cable. Pins 2 and 3 are switched when going from laptop to palm serial connections.
Radio shack should have them, or open the 9 pin connector on your diagport/laptop cable and get an rs232 pin removal tool and switch pins 2 and 3 in the db 9(pin) connector side.
TalonTSi-AWD91 said:
MMCd is for 1Gs only, it doesn't support OBDII.
Bamm Just found that out also, guess the only way to go is the $125 for the pocketlogger.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
