Logging MMCD 1.71 and MMCD1.8g
eclipsegst1990
118
Mar 15, 2005
GLOUCESTER CITY, New Jersey
Just a few questions regarding MMCd FOR EXPANDED FUEL & TIMING MAP USERS 1.71.01132005E found at http://www.ecimulti.org/mmcd/ and MMCd 1.8g doesn't seem to offer.
I need to use the 1.71 version of MMCD so I can log the g/rev while using Tunerpro to help me find which grid section needs adjustment. This also allows me to log in the extended 3200hz region. The problem is, version 1.71 does not include the capability (as far as I can tell) to log my WBO2 signal as in 1.8g. Is there a function that I can add in 1.71 or 1.8g to have the best of both worlds? Is it possible to install two versions of MMCD on one PALM and switch between the two (I've tried installing both versions, but it only takes 1 version only)? Can someone please try and post a detailed way of adding these capabilities into either version of MMCd.
Note: I see that E3 is for WBO2 in 1.8g, could this be as simple as adding address E3 into the "custom sensors" area under preferences in version 1.71 and naming it WBO2 or do I have to add a mathmatical function in the debugging section?
The whole point of this is to be able to see what load row I'm in on my logger so I don't have to keep looking at the hz, timing advance, and rpm. (see below)
Internal (log): 32 48 64 80 96 120 144 168 192 216 240 264
stock g/rev: 0.25 0.38 0.50 0.63 0.75 0.94 1.13 1.31 1.50 1.69 1.88 2.06
ext g/rev: 0.50 0.75 1.00 1.25 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13
Any help would be appreciated
Thanks in advance.
No ideas? Can someone at least suggest a way to program g/rev in version 1.8? MMCD would be deadly if I could combine g/rev with MMCD's WBO2 logging. :toobad:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
