ECUflash Logging knock on 1999 evoscan
yepes281
971
Mar 22, 2009
H-Town, Texas
I know on the 1997s and below you have to change it to 3E to see the knock sum, is there something you have to do for the 99's?
450 injectors, 255 walboro, a regulator set at 44psi no vac, E316g creeping to 20psi, and its showing no knock. I just have a hard time believing this.
Nope, nothing to do there.
Have you logged your IDCs? Are they approaching 100% or well above it? You only get lean knock if you go lean. I know from personal (and scary) experience that I can hit 11.8:1 at 275 load and more aggressive than stock timing without knock though I'm sure doing that more than once or twice on accident would be disastrous or my motor anyways on pumpgas.
