EVOscan evoscan 2.9 logging issue
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
Need help guys. Blackbox ecu in a 1g, trying to log with evoscan 2.9 and getting this error after it logs for like a second or two:
Info: OpenPort 2.0 Found.
Info: OpenPort Firmware v1.15.447
Info: Battery 13.637V
Info: Initialize Vehicle ECU...
Info: Initializing At 5 baud...
Info: Timer: 2114.6968ms
Info: Initialization Complete...
Info: Waiting for INIT Response...
Info: ECU ID: E4B0
Info: Connection successful...
Error: J2534 Read Error - 16
Info: Datalogger Ended.
This is the settings I use. When i start evoscan I get a bunch of different errors about double files or something. I can read dtc codes but cant clear them as well.
Try selecting a different ecu in evoscan like "efi" and try hitting start again. Your using a black box ecu out of a 2g I take it?
If I recall I tried connecting with selecting different ecu's set in evoscan. Some would work and some wouldn't allow me to connect or fully log.
Let me know if this helps, if not you could try running an earlier version of evoscan and see if it works. We'll get this figured out with you.
Also you did download the ecu flash files for evoscan as well right?
