Loggin advice needed.
SiNiST3R
347
May 10, 2004
NorCal, California
Ok so after work and looking around on tuning i think i may be off, if ya fellow DSMers can help me out Sweet. Here is a posting of my Log.
Rpms: 1932 O2: 0.79 TPS: 10 Timing 27
Rpms: 1960 O2: 0.19 TPS: 44 Timing 27
Rpms: 2008 O2: 0.84 TPS: 96 Timing 18
Rpms: 2152 O2: 0.9 TPS: 96 Timing 19
Rpms: 2280 O2: 0.9 TPS: 96 Timing 19
Rpms: 2416 O2: 0.91 TPS: 96 Timing 16
Rpms: 2548 O2: 0.91 TPS: 96 Timing 15
Rpms: 2688 O2: 0.91 TPS: 96 Timing 15
Rpms: 2840 O2: 0.91 TPS: 96 Timing 13
Rpms: 3028 O2: 0.9 TPS: 96 Timing 11
Rpms: 3212 O2: 0.94 TPS: 96 Timing 9
Rpms: 3428 O2: 0.94 TPS: 96 Timing 5
Rpms: 3692 O2: 0.96 TPS: 96 Timing 6
Rpms: 3920 O2: 0.96 TPS: 96 Timing 5
Rpms: 4196 O2: 0.96 TPS: 96 Timing 5
Rpms: 4444 O2: 0.96 TPS: 96 Timing 5
Rpms: 4652 O2: 0.96 TPS: 96 Timing 7
Rpms: 4872 O2: 0.96 TPS: 96 Timing 8
Rpms: 5076 O2: 0.96 TPS: 96 Timing 8
Rpms: 5280 O2: 0.96 TPS: 96 Timing 11
Rpms: 5508 O2: 0.96 TPS: 96 Timing 8
Rpms: 5660 O2: 0.96 TPS: 96 Timing 9
Rpms: 5868 O2: 0.96 TPS: 96 Timing 11
Rpms: 6036 O2: 0.96 TPS: 96 Timing 10
Rpms: 6192 O2: 0.96 TPS: 96 Timing 10
Rpms: 6344 O2: 0.96 TPS: 96 Timing 12
Rpms: 6496 O2: 0.96 TPS: 96 Timing 12
Rpms: 6620 O2: 0.96 TPS: 96 Timing 12
Rpms: 6772 O2: 0.94 TPS: 96 Timing 13
Rpms: 6892 O2: 0.94 TPS: 96 Timing 14
Rpms: 7004 O2: 0.94 TPS: 96 Timing 14
Rpms: 7108 O2: 0.94 TPS: 96 Timing 15
Rpms: 7204 O2: 0.94 TPS: 96 Timing 16
Rpms: 7312 O2: 0.94 TPS: 96 Timing 16
Rpms: 7412 O2: 0.29 TPS: 1 Timing 38
I have the basic mods for a 2gen FWD; turbo back,550s,fpr 43,safc2,evo3b16g,walbro255 yada yada..(I do not have a EGT yet ;(..)
Am runing 19-20 psi i belive this run was @20 psi
Please any Advice would help alot. Thanks Guys. :dsm:
You need to add some fuel in the 5000-6200 rpm range as suggested. You could also bump up the fuel pressure a bit and pull more fuel out to get better timing advance as well.
~Mark
Thanks ill give that a try, What asbout the 3k-4k range or does that look about right?
