kpt4321
- 3,383
- 17
- Jul 30, 2002
Pizzy said:One thing that's a little confusing...
With the side and lower honeycombs out, wouldnt the ECU still see the same 1000hz of airflow since the passage that the sensor sits in is unaffected? I thought that by removing the honeycombs the ECU sees the same amount and the actual airflow increases because it is "sneaking" around the sensor, causing a lean condition.
Thanks for not biting my head off.
Read my post, where I explained how airflow is not going to increase. All that happens is the MAF outputs a smaller airflow signal for the same true airflow, which is the same thing that happens when you go negative on the SAFC.
