2G Locked glove compartment
Jammed how? Like jammed full?
Did you try putting pressure on the glovebox while keying in and turning with a little wiggle?
Otherwise Amazon lock pick set would probably do it.
I have that problem too. The buttons dont push in right? My mechanism got jammed somehow and is in a perpetual state of being locked.
The key wears over time, so it's difficult to get it to line up correctly to unlock it. I try all the keys I have, and push the key in slightly, try to twist it, pull it back slightly, try, try, and try again, and eventually it (usually) opens. It usually takes a lot of tries and a lot of patience.
