TURBOKIDD90GST
- 81
- 0
- Dec 13, 2005
laurel,
Maryland
Electrical componet locations for 90 eclipse gst
A/C Control Unit: RH Side Of Instrument Panel
Accelerator Pedal Switch: LH Instrument Panel On Accelerator Pedal Bracket
Air-Flow Sensor: On Air Cleaner Housing
Air Inlet Sensor: RH Side Of Instrument Panel
Air Thermo Sensor: RH Side Of Instrument Panel
Alternator Relay: RH Side Of Engine Compartment
Auto Cruise Control Actuator: RH Side Of Engine
Auto Cruise Control Unit: Upper LH Side Under Instrument Panel
Automatic Seat Belt Control Unit: Lower Front Of Rear Quarter Panel
Automatic Seat Belt Motor: Lower Front Of Rear Quarter Panel e Front
Automatic Seat Belt Motor Relay: Lower Front Of Rear Quarter Panel
Auto-Cruise Control Diode: Center Of Instrument Panel
Blower Motor High Relay: Bottom Of Blower Motor
Buzzer: LH Center Of Instrument Panel
Clutch Pedal Switch: LH Under Instrument Panel On Clutch Pedal Bracket
Condenser Fan Motor High-Low Select Relay: LH Rear Engine Compartment
Condenser Fan Motor Relay: LH Rear Engine Compartment
Coolant Temperature Sensor: RH Side Of Engine
Crankshaft Angle & Top Dead Center Sensor, Except Turbo: RH Side Of Engine
Dedicated Fuses: LH Rear Of Engine Compartment
Dedicated Fuses: RH Side Of Engine Compartment
Detonation Sensor, w/Turbo: Rear Of Engine On Cylinder Block
Diagnosis Connector: RH Side Of Fuse Panel
Door Ajar Warning Diode: Near LH Sill Plate
Door Latch Switch: Inside Door
Door Lock Control Unit: RH Kick Panel
Door Lock Relay: LH Lower Instrument Panel
Dual Pressure Switch: RH Side Engine Compartment
Electronic Control Unit: Behind Center Console
EGR Temperature Sensor, California: RH Side Of Engine
EGR Control Solenoid Valve, Except Turbo California: Rear Of Engine Compartment Near Battery
EGR Control Solenoid Valve, w/Turbo California: LH Rear Engine Compartment
Engine Control Unit: RH Side Of Console
Engine Coolant Temperature Switch, Except Turbo: LH Side Of Engine
Fasten Switch: Upper Front Of Rear Quarter Panel
Fuel Pump Chock Connector: RH Rear Engine Compartment Near Battery
Fuel Pressure Control Valve, w/Turbo: LH Rear Engine Compartment
Fuse Panel: Under The LH Lower Instrument Panel
Headlight Pop-Up Diode: RH Kick Panel
Heater Relay: Lower LH Instrument Panel Above Junction Block
Idle Switch: On Throttle Body
Ignition Coil & Power Transistor, Except Turbo: LH Rear Of Engine
