14b with 16g componets?
shadow001dsm
183
Mar 26, 2009
las vegas, Nevada
I am in the middle of putting a new head on my car and figured since i got the time and i just wanna know.... i have a stock 14b on my car and i just happened to have a 16g center cartridge and cold side, i was wondering if i can switch the center cartrigde on the 14b and the cold side out and put the 16g compents in.(is a 16g small i think, the numbers are as follows, tod5h a3 6f
S 070713077
49178-0
if anyone knows what all those numbers means then that should say if a big or small. )
so is it all interchangable?
it you use the 16g center "where the bearings are" then you'll have to have the 16g compressor wheel. they are slightly different then the 14b. look at the big sides side by side and you'll see. the cold side housings are the same and the hot side will fit into a 14b housing. the 14b hot side housing is slightly smaller then a 16g but not by much.
set up should look like this-
16g center and compressor wheel
16g hot side turbin
14b cold housing
