16g turbo with 14B wastegate???
What exactly are you talking about, just the flapper? The housings are 6cm/7cm, not sure exactly on the wastegate size, but I would assume they are interchangable. If you are meaning the entire turbine housing then yes you can swap them out.
From what i heard they are basically the same part. So yes, it should work......BUT don't hold me to that, i may be wrong.
