spoonman
Supporting VIP
- 864
- 33
- Jul 20, 2007
Omaha,
Nebraska
I have used an aluminum crankshaft pulley on one of my engines for years (4-5), with no ill effects. The car is a DD with around 350 HP. The engine was built with an OEM 6 bolt lightened crankshaft, aluminum rods, and lightened JE pistons (extremely light rotating assembly). It has a very light weight aluminum flywheel also. The crankshaft was properly balanced, believe it or not but I-4 crankshafts do need to be lighted and balanced if you use different rods and pistons. If your machinist try's to tell you that I-4 engines are naturally balanced slap him in the face.
Torsional vibration can not be eliminated but it can be reduced, by lightening the rotating components thus effecting the moment of inertia.
I started using one after stumbling into a thread on NABR with many members using them for YEARS. Although it was still debated as to whether or not using a aluminum pulley would cause catastrophic failure on a properly built engine. If anyone wants to compare the two, put both on an engine dyno and examine the torque figures. If the aluminum pulley has lower torque figures it will be the result of the crankshaft flexing.
Although a heavy rotating assembly does help keep the RPM's from falling off when you shift, a heavy rotating assembly does not help any vehicle accelerate from a stop. This is a very common misconception. Rotating components store rotational energy as well as having to be accelerated in a linear direction. The faster a component rotates, the greater the amount of rotational kinetic energy that ends up being stored in it. The absorption of this energy could be seen as adding more weight to the entire vehicle itself.
. The rotating mass helps launching the car and keeping the revs up when shifting.
. I just hate how a company like unorthodox says its totally ok to run one but fluidampr says its better to have one of theirs. Both companies are trying to sell you a product so who are you supposed to believe. Unorthodox has been selling these for 13 years it says it right on their site. I don't see how somone could make a product that's so dangerous for an engine and get away with selling them for so long if that were really the case. Believe me guys I like taking care of my engine I just have never really seen any hard proof that the lightweight pulleys cause damage. In the end I guess it would be best to get a fluidampr as they are around double the cost of a new oem pulley but will last forever and haven't had any bad reports that I know of.
