lifter question
trackfwd
Nov 30, 2009
San Diego, California
I'm about to remove my 1g head to get rebuilt, when I remove the lifters,do I just reinstall them as is when the new head is in,or do I have to bleed them ,btw these are my original lifters from the same head
You should be fine. When you install the cams after awhile the lifters will bleed down by themselfs. If you were say just doing a cam swap and starting the car up shortly after swaping out new lifters and cams then I would bleed them down.
