Lets talk 68HTA
I wasn't sure if an engine build was in the works.
If your reading this thread (anyone, not just those who posted), and are thinking about a v2 68hta with a stock or lower compression 2.0 or want a weekend drag car, I (and others I'm sure), would HIGHLY suggest buying an FP Green instead of the 68hta. The green flows 6 lbs / min more, and doesn't require a J pipe.
http://www.forcedperformance.net/me...uct_Code=NTDSMFPGREEN&Category_Code=DSM-Turbo
My v1 68hta hits 20 psi around 3500 rpm and holds it well until redline. It has the kamak 9 blade turbine wheel instead of the standard 12 blade. The difference I noticed when I switched was more top end flow, and slightly quicker spool, but at a later RPM (start at 2900 full boost by 3500 as opposed to starting at 2700 full boost by 3400). I did also switch from an eBay manifold to an fp manifold at this time, so I can't be for sure what changed what.
My supporting mods are an ets street intercooler and short rout piping, fic 950cc injectors, evo fuel pump, and street tuned with ecuflash.
This setup ran just under 103 mph in the quarter mile with a full interior and a passenger (est. 3600 lbs total) in my awd at 18 psi while I was in the tuning process. I've since upped the boost and worked out some kinks in the tune.
I went straight from the stock t25 to this turbo, so I have nothing else to compare it to. I'm used to the tiny amount of lag it has, and it has great top end power. From what I hear, this little turbo has even more potential. My next upgrades will be e85 and cams.
Long story short: I think the v1 68hta is a versatile street turbo with respectable power and has OE fitment.
I finally got my V2 Hta68 8cm installed.
I am real happy with the turbo. It is definitely making more power. I will be taking it to the drag strip on Saturday. It spools faster than my eBay 16G I was running and is making more torque down low. In the days to come I will try to have video posted of the runs and spool times. I'm currently running 21psi tapering to 19. Running about 15-16 degrees advance.
It's because you're running lower boost and no cams I'm guessing.. I have fp2 cams and I hit 20psi around 4000rpm and peak (28) around 4400. Gotta remember that spoolup is relative to CR, displacement, max boost level, the tuner, the fuel.. ehh you get the idea. there is a lot of variables.
I am taking my car to the Dyno at fat house fabrication in Martinsville IN.
I will have the dyno for one hour. I will try to post results on the HTA68 V2.
Mods:
Delta Regrind Cams 264/272
750cc RC Injectors
Coolingmist Trunk Mount Water/Methanol kit 390cc injector
Forged .020 - WESCO PISTONS: 8.5:1
Stock Rods/Bolt
HTA68 V2 8CM
Sbc Stage 1 Head.
2g Exhaust Mani
2g Mas
3.5 inch Intake Inlet
Aeromotive AFPR
Walboro 255lph
2.5Inch Down Pipe
Ebay O2 dump
STM Full Length 3 in exhaust
Stock BOV
Ebay Front Mount & Piping Long Route
2600 Act Pressure Plate
Competition Street disc
GVR4 Transmission Taller first gear
APSX wide Band 02
SAFC 1
Tuned Chip from Tuner "Bastarddsm"
Currently on 25 psi Low Timing.
Have absolutely no idea what kind of power it will make.
For Indiana guys here is the website for the AWD dyno.
https://www.fathousefab.com/
Fat house huh never knew a shop close to my old college. Right down 37. Nice to have a base point when you hit the dyno them hi from there I have a base now. Big
Changes next year. Keep us updated.
