Lean Running p0170
MEz
152
Nov 9, 2011
Gilbert, Arizona
reset the ecu a few times and check engine light still came on. need help determining whether its the 02 sensor,MAF, fuel injectors, or fuel pump
p0170 Usually means the front o2 sensor is bad.
yeah might be 100% right, my t-25 blew an oil seal and started to burn oil. so i replaced the turbo but kept the same o2 housing and sensor. But when i do reset the ecu the check engine light turns off for at least 15-20 miles then comes back on
is this because the sensor is bad or its truly burning lean. :confused:
I'm running with a p0170 code and watching my front O2 on a scan tool, it seems to freeze up at times, which I know an O2 should be constantly fluctuating. I'm going to replace mine and see if it'll make the code go away
Update: Replaced the front O2 and the code hasn't come back at all. Long Term Fuel Trim is now working like it sould be
Could there also be the possibility that it is burning lean? If so what should I do?
Did you clear the code or replace the sensor, it may return, its happened to me in the past. A wideband would be nice to have for tuning down the road.
Yeah I reset the ECU but every 15-20 miles the light comes back. Should i replace both O2's or just the front one? :confused:
Yea I got that too if your running just a 14b on stock everything else maybe upgrading your fuel pump should help.Do you have a wideband or boost gauge to see whats going on?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
