leaky transfer case
Status
Not open for further replies.
spoolinNpullin
Nov 27, 2005
aston, Pennsylvania
Hey guy's I just bought my car, 1990 eagle talon tsi, awd turbo, manual trans. I am in the middle of replacing all of the worn out bushings and suspension parts etc..... anyway I am having trouble with my transfercase, it leaks at the seal were the driveshaft yoke goes into the t case. I have replaced the seal with a brandnew one from the dealer and it is still leaking. The weird thing is the oil looks like it is coming out of the yoke, but there isn't a hole there. Thanks for reading, also if I don't reply for a little bit that is because my computer is broke at home, I use the computer at work and i only work mon through fri. I am also new on this site so I still have to figure everything out.
:talon:
This is a design flaw in the transfer case yoke. You are going to have to take it into a dealership and have the recall fix done. Alot of dealerships are a pain to get the recall done again on the vehicle but don't give up. Keep pressing and check multiple dealerships as it is very dangerous to have all 4 wheels lock up when you run out of fluid :| .
Check this link for all the details http://members.shaw.ca/costall/1000Q/answers-recalls.htm#Whatiswrongwiththetransfercase
Good luck in getting it fixed.
Status
