forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
My car never had any real leak issues until I recently replaced the motor. After installing my transfer case I noticed I was getting a drip from the driveshaft input seal. So after dropping the case and installing new input and output seals I still have the same issue? When filling the case I leveled the car out on jack stands. (just eyeballed it). Then added fluid in the top until it started to pour out the fwd fill plug.
Is it normal for the transfer case to weep a bit until it finds a happy fluid level? Im getting a puddle about the size of the avg pancake parking it overnight. It does not appear to leak at all when running.
Thanks!
Thanks!
Maybe you were low enough on fluid that it just wasn't leaking and now that you have filled up the new transfer case it is full enough to leak. Just a thought. Good luck.
Get the kit and you'll be good to go.
