Leaky Sunroof
bigrick_00
May 16, 2010
Summerville, South Carolina
So everytime it rains my sunroof leaks and drips all over the driver and passenger seats. If it rains hard enough the water will also leak down and soak my head liner to the point where it drips off of that too. Anyone know how to fix this problem? If so any help would be appreciated!
There's a drain pipe opening in each of the four corners of the sunroof area that are really easy to get to if you take the sunroof out. Whenever mine get clogged I just push some weed eater wiring through till it comes out the other side. The other side will be around the wheel area of the car on the same side that the opening in the roof is. Try doing something like that.
Also, when you do that you could try just pouring water into that area and see which drain is plugged. If none of them are it might have rusted through in an area. Mine almost constantly causes me problems. It will be solved one day I swear it.
If you have an RS eclipse you may have the sunroof that has no drain hoses. I am having that same problem with my sunroof leaking and when I looked my sunroof it has no drain hoses and I don't know what to do.
taking off the headliner will revel the drain tubes...they are held on with just clamps.
...and if you are in the market for a new sunroof...PM me. i have one sitting around ^_^
  • Wanted 6 bolt NT water pipe
    • chrisman287
