leaking coolant from the main line that feeds turbo
dsm5150
464
Feb 19, 2003
vacaville, California
i have a coolant leak that appears to be coming from the line that goes to the turbo.its the front line that comes up from under the turbo that bolts to the front of the turbo.its leaking from this line but behind the turbo were it connects with the bigger gray pipe that runs horizontal with the motor.anyone ever run into this?if so how the hell do i fix that?
The coolant lines running to the tubocharger have copper crush washers that act as gaskets.
These crush washers are not reusable and should be replaced any time the line is removed.
If you are experiencing a leak from one of these lines, simply replace the crush washers that seal them.
ALL crush washers are new.its NOT leaking at the tubo but were the turbo gets the coolant from.
Is this a hardline or a rubber line? If it's rubber make sure there isn't a pinhole in the line itself and that the clamp is placed on enough of the hardline to make up the connection.
Otherwise I'd check for cracks in the hardline from road debris or such. I've seen stranger things happen. Also check your crush washers, they should look something like:
head of banjo bolt | crushwasher | hardline "O" | crushwasher | turbo
its coming from the hard line were it connects with the main feed.
