Resolved Turbo coolant line torque
I'll give you the torque specs that were given to me by another wiseman a few years ago when I did my 14b swap. If you're using a non-TD05 turbo, they may be different.
Mani-turbo bolts- 40-45 ft-lbs.
Water lines- 22 ft-lbs.
Oil feed - ~19 ft-lbs.
Oil drain- ~14 ft-lbs.
If anyone has a second opinion on this, please feel free to correct me.
According to 1G FSM, 14b, the coolant banjo bolts should be torqued to 25-36 ft-lbs, probably the same for a T25.
