Rock2610d
- 255
- 4
- Jan 22, 2013
Cheyenne,
Wyoming
So, my wide band is acting funny.....or maybe its my engine.
Everyday normal driving the A/F ratios are pretty good...14.3 to 14.9.
Issue is when I get on it a little and boost goes above 10 psi, my wide band shows about 10.5 to 11.5...pretty normal. But if I let off the air pedal just a little and continue driving without boost the A/F ratio will be 11.5 to 12.5 and will stay in that range even while engine is in vacuum.
However, if I let all the way off the air pedal and push the a/f ratio up to 21 or so and then push gas again the a/f ratio will go back to 14.3 to 14.9.
Why after a 10 psi or higher boost do I have to completely let off the gas pedal to get a/f ratios back to 14.3 to 14.9?
