Launch control flat shifting on MS EXTRA questions about clutch switch
GSTurbo1
610
May 2, 2012
Pickens, SC, South Carolina
First of all just got my car boosting hard and tuned well. The car came with the MS wired, I'm not sure if it has a clutch switch or not for the flat shift. Do I need to set the arming rpm higher or lower than the the other two for the flat shift on the variable setting.
the question is... how do I make the launch control system retard timing at a certain RPM when the clutch is engaged? What do I need to put the settings at?
What switch activates the launch control? There is a switch on the clutch that you can wire it into but you wont have to push in the clutch to start the car. Or install another clutch switch
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
