Largest injectors with SAFC II?
Game Over
1,267
Jun 30, 2004
Aston, Pennsylvania
Yo, I have basically all of stage 1 and 2 done in the tuning guide except the injectors. I'm running an internally gated 50 trim with 255lph hp fuel pump with a safc II. What is the largest injector size you can use with a SACF II because I know it is different on every application.
BTW, I was planning on going with PTE 680cc's.
i think 750's is the max you can use with the afcII but 680's will be fine for your setup
you will be just fine with the 680's. You will be at about -24 to about -30 through out the rpms.
