Lancer Evo 2 engine build list
Mspec
Oct 12, 2025
Østbirk, Europe
Hello,
My Lancer Evo 2 spun a rod bearing, I am now rebuilding my engine and need some advice.
- What have been bought so far
Block bored to 85.5mm and decked
Wiseco 1400HD pistons
ZRP I-beam rods with 3/8 ARP bolts
Manley 190100 crank
New OEM oil pump
Kiggly balance shaft delete
Kiggly 12-1 trigger
ARP main studs
ARP Customage 625+ head studs
Supertech black nitrided valves
GSC 1003 Valve keepers
GSC valve seals.
Are the Kelford 272, enough or to harsh? And I can’t figure out between GSC5040 or 5041 valve springs. What is the downside to higher seat pressure?
What I can’t figure out is the cams and springs.
I am looking to make 400-500whp, it is a weekend car, so not a daily. But not a race car either.
It will run on RON100 octane / 96 AKI octane
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
