kyb agx struts and coil system. which one?
kelvinb
726
3
May 7, 2004
Lincoln, Nebraska
i got some kyb agx struts that do not have the factory spring holder things. i was wondering what coilover system i could use with this? i was told that the skunk2 system was used, what other alternatives do i have? thanks
Maxspeed coilovers also require that you remove the spring perches. The front ones can be knocked off with a mallet, so you can always knock the ones off of your stockers and use those. The rears are welded on, so it's not as easy...
