GCC's and KYB AGX
Lunch_Box
2,137
15
Mar 14, 2003
Sherwood Park,
I bought a set of used Ground controll coilovers and KYB AGX shocks for my car and I was wondering if anyone else with set up can help me out. What are the stock spring rates on the ground controll coilovers? Also what would be a setting for the AGX?
i have that setup on my talon. run 4 in the front 5 in the back. pretty stiff but i dont mind.
Maybe 1G's are different that 2G's but mine only have 4 settings.
RamenPride said:
450f/300r
not sure if it's different for AWD
um, not sure where you got that information...
with the agx shocks, run full stiff in the front, and depending on what mods you have for the rear (sway bar, tie bar, stb, etc) play around with it but dont go anywhere near full stiff. to stiff and the car will oversteer. i have my rears at 5-6 and i love the way it handles, very neutral.
RamenPride said:
175 different Eibach Springs can be matched with GC coilovers, with many...many different spring rates. thats just the spring rate YOU got.
yes, I am well aware of the fact that you can order them with different spring rates. besides, the guy asked what the stock rate was. the default rate for FWD at least is 450f/350r, hence the reason for my reply. if you read the original post, the question was what the stock spring rate is. is it possible that the person he bought them from ordered them with different spring rates? yes it is...
anyhoo, if you post whatever is stamped on the springs I'm sure someone can figure out the rate for you.
